Adding Navi to 2006 SE with nothing
Old Dec 13, 2020 | 09:21 PM
rdsmvp's Avatar
Exclamation Adding Navi to 2006 SE with nothing
Ladies/Gents,
Did a search here and the closest topic is from 2009 so I am sure a lot has changed in the past 12 years.
I just got a very nice well maintained 2006 SE V8 but no Navi, just that 'hole'/'space' in the dashboard. I am wondering what others have done to add a nice unit like Kenwood/Pioneer/Alpine that would fit there and bring all the tech available today to the car.
Plan is to leave the current radio as it is and if possible plug a new one, installed on that space, to the AUX of the existing one (I assume there is an AUX). If this is not possible, what is the best approach? If I remove the existing radio, do I lose anything?
Just wondering what the options are.
Cheers.
CR
Old Dec 14, 2020 | 12:20 AM
loanrangie's Avatar
Look on Aliexpress, there are units made that fit that space perfectly and hook into the factory harness for a factory look.
https://www.aliexpress.com/item/4000...archweb201603_
Old Dec 14, 2020 | 08:24 AM
rdsmvp's Avatar
Interesting! As I am picking up the car on Saturday I am not 100% sure if it has the MOST network. I assume not as it is a simple V8 SE 5-seater. In that case if I replace the stock radio, would I lose anything? These Chinese units I have no idea how good they are and the Pioneer NEX seems like a good alternative from a well-known brand. Wondering if anyone used a NEX unit on the LR3.
CR
Old Dec 14, 2020 | 12:33 PM
Blackngold77's Avatar
https://landroverforums.com/forum/lr...install-92060/
nearly a perfect fit if you are only going for navigation (not my build but plan on doing it eventually). Can get them used or refurb'd for under $100
Old Dec 14, 2020 | 03:48 PM
loanrangie's Avatar
CR
You most likely dont have an optic system so replacing the head unit you will only loose the clock in the dash, probably 95% of head units are made in Asia so origin is no issue really.
My CD player died so i just fitted a 7"android unit.
njdefendernj
Dec 1, 2020 06:36 PM
EastCoast
Apr 16, 2018 10:46 PM
cnazario
Mar 2, 2016 09:33 AM
itcookie
Aug 31, 2009 09:13 PM
amaclellan
Aug 11, 2009 07:17 AM
