Advice on a few oil leaks
Old Dec 29, 2018 | 09:56 PM
2006 LR3 HD package's Avatar
Default Advice on a few oil leaks
Hello all. Looking for advice or links to repair write ups to fix a few oil leaks.
Vehicle: 06 LR3 4.4L with HD package
Oil leaks:
Power steering rack.
Front driveshaft
Rear driveshaft
Rear differential
Pictures attached (hopefully)
Old Dec 29, 2018 | 09:59 PM
Pictures attached this time.
Old Dec 30, 2018 | 08:42 AM
abran's Avatar
Rear diff- can’t tell on the pic where it’s leaking, you can try new seals at the sides/axles, but I find that the bearings have play in them and that play causes the leaks. If that’s the case, rebuild diff.
front drivesgaft- actually is the front difftube. Remove and replace needle bearing at end and a new axle shaft seal.
rear driveshaft- replace whole assembly.
Old Dec 30, 2018 | 09:01 PM
Thanks abran.
Do you know of a good resource for completing these projects: haynes manual, link to a land rover mechanic manual?
What fails on the rear driveshaft, never owned a vehicle that failed a driveshaft.
Old Dec 30, 2018 | 09:14 PM
abran's Avatar
The CV is failing on the rear driveshaft.
There are no good resources I know off for the repairs. There is a factory manual that you can find downloads for, but it won’t help with the diff rebuild.
KTriplett
Nov 13, 2017 09:12 AM
Jadden14
Oct 16, 2017 07:11 AM
batard
Jun 5, 2016 07:01 AM
thorgal
Dec 8, 2014 09:02 AM
kenk
Jun 1, 2009 09:42 PM
