Air drier rebuild...
Old Aug 28, 2015 | 02:49 PM
techniq808's Avatar
Default Air drier rebuild...
looking at workshop manual for the Filter/Dryer removal and it just says:
5 . Disconnect the air suspension intake filter pipe.
6 . Detach the air suspension intake filter.
Release the grommet.
Release from the clip.
Am I disconnecting from plastic cylinder behind the spare wheel well?
Also, where exactly is the air dryer?
is it the cylinder behind the wheel well?
is it in the rear inside quarter panel access? (I don't see it there)
is it with the compressor?
Old Aug 28, 2015 | 05:05 PM
morrisdl's Avatar
The air dryer is part of the compressor assembly.
Old Aug 28, 2015 | 05:29 PM
Airstream345's Avatar
Yep, gotta remove the compressor assembly first. Comes out a single unit:
Then you need to remove the drier, replace the filters and desiccant:
It's about a 1 - 1.5 hour job.
Old Aug 28, 2015 | 08:23 PM
techniq808's Avatar
Thanks everybody, I was looking at the filter doc in the workshop manual, DUH!
I had watched the Lucky8 video and stumbled on the compressor install video shortly after this post.
What the heck was LR thinking with the placement of that 3rd upper 10mm bolt for the aluminum compressor bracket! That was a PITA!!!
Anyway, job's done and got a 2nd kit for my wifes L322 I'll be doing tm!
FlyingZebra34
Jul 31, 2013 06:00 AM
Road Stone
Jun 24, 2013 03:01 PM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
