Air suspension - Height setting possible
Old Aug 9, 2021 | 08:56 AM
keninnc's Avatar
Default Air suspension - Height setting possible
I'm getting an air suspension fault but can't seem to get a code using my Nanocom. I just keep getting CODE: UO132 Lost communication with ride level ctrl module.
I'm also getting 4 other similar codes all that are lost communication such as the tire pressure even though I don't have tire pressure monitors.
I also don't have the center dash screen so I'm unable to see 4x4 mode
While using the Nanocom to to diagnose the air suspension the Height control page shows the following picture.
Rear Right Actual Height is not a stable number changed by 1 up or down from -6
Also, I have put the LR3 into off-road mode and pulled the fuzes. Rear barely lost any air after 48 hours. The front lost about 3/4 an inch. So I am thinking the bags are good but possible front valve block is leaking back into the system but not enough to throw a code.
Old Aug 11, 2021 | 02:19 PM
Gnomadf's Avatar
You lost communications errors may be related to the begiining of a failure in your instrument cluster. In otther words you don't have a suspension failure so much as a comminication issue within the vehicle modules and often that all comes together in the instrument panel.
Does a Nanocom allow you to read the inputs a,d outputs? I've also had suspension issues and I could look up the air pressure and control state of the compressor,
Old Aug 11, 2021 | 08:44 PM
keninnc's Avatar
Yes the Nanocom has the ability to see the inputs for actual heights, valve % for each corner, reservoir valve%, exhaust valve %, front and rear cross link valve% gallery pressure, compressor temp and motor temp
I think you may be on to something about the instrument panel. This morning I drove the LR3 when it was around 82 degrees outside. Late afternoon I took another drive and the temp reading was 82 even though it was in the 90's outside and the low fuel light came one. I stopped the engine to run into a store and when I started it back up the temp instantly changed and the gas level changed as well with more gas showing and the light was off.
I just solved water getting in the front right sill. The fob works but there was a lot of water surrounding the wires in this area.
Chum
Oct 6, 2021 06:35 AM
Ryan2016LR4
LR4
May 8, 2021 08:00 PM
paulblake
Aug 8, 2020 09:03 PM
erick846
Feb 11, 2016 09:34 PM
Orkney LR4
LR4
Mar 11, 2013 11:52 AM
