Air Suspension leak, What's this?
Old May 31, 2021 | 11:57 AM
Perfectphoto's Avatar
So how often does your compressor comes on? Maybe mine is just normal?
Old May 31, 2021 | 11:58 AM
DakotaTravler's Avatar
Probably every 10 minutes or so. But with a healthy system it should not come on often at all unless there are height changes or articulation.
Old May 31, 2021 | 12:05 PM
Well, guess mine isn't that healthy then. I will keep messing with it and see what I find. My son took it to LA for the weekend I will mess with more tonight. I will post what I find.
Old Jun 1, 2021 | 03:46 PM
Chris Gatan's Avatar
Can you use "live values" to diagnose? If so what would be triggers to monitor?
Old Jun 1, 2021 | 11:01 PM
houm_wa's Avatar
Mine comes on fairly often during the first 5 minutes after startup, then it's not frequent at all unless I drive on uneven terrain.
Old Jun 3, 2021 | 08:53 PM
Pretty sure you can observe the height sensor value. You can observe gallery pressure, but that will usually be low/zero until the compressor fires up or the reservoir is opened.
Rustic
Jun 19, 2020 07:15 AM
LRTHREEE
May 19, 2018 10:59 PM
Drome
Sep 3, 2017 08:41 PM
RyanB
Jul 2, 2014 10:07 PM
wsroufe
Feb 8, 2011 09:48 PM
