suspension problems
Old Jun 2, 2021 | 03:40 AM
bricer's Avatar
3rd Gear
Default suspension problems
Hi Ive recently bought a second hand Discovery TDV6 2005 ( dont laugh) i was getting an Orange warning light on the suspensionso went to a garage.They fitted a new pump ,but now i have a red warning light.The mechanic said i needed a new Ride height control module.He has now closed the garage for a month and gone on holiday! leaving me with this problem.I want to look up the price of this part so can anyone tell me the part number or the best place to look for one,i live in Spain
Old Jun 2, 2021 | 05:56 AM
Rufflyer's Avatar
We would love to help we do it every day here on this forum), but we do need some more information. By chance did you mechanic give you the ODB diagnostic codes that lead him to replacing the compressor?
Please don't feel offended, but diagnosing these things is hard enough, even harder through the internet. The diagnostic codes tell us a lot about what is going on with your car, even if the code does not seem directly related to your immediate problem, it may be.
Again, would love to help, but we need the codes.
Jeff
Old Jun 2, 2021 | 06:31 AM
bricer's Avatar
3rd Gear
Thank you for the reply,i shall try and get the code but unfortunately the guy is on holiday now.
Old Jun 2, 2021 | 05:39 PM
houm_wa's Avatar
Does the compressor operate? Does the red light come on only at a particular speed? What does the LR3 when the red light comes on?
Old Jun 3, 2021 | 01:18 AM
bricer's Avatar
3rd Gear
NO the compressor does not work now,the car is stuck at ride level
Old Jun 3, 2021 | 01:24 AM
loanrangie's Avatar
Get onto the disco3 UK forum as there will most likely be some one that can read the codes for you,
Old Jun 3, 2021 | 12:35 PM
houm_wa's Avatar
...also, find a new mechanic!
Old Jun 3, 2021 | 08:50 PM
DakotaTravler's Avatar
Red fault is almost always a hard fault. Meaning a bad really, fuse, disconnected component, etc. I very much doubt its the module, possible but doubtful. I would swap relays and check fuses. I would also remove the lower acoustic cover of the compressor and make sure a connector for the compressor did not pop apart. Maybe it was simply not connected well. There are two, one is two large wires for power the other is a six wire connector for all the other compressor stuff. Then I would examine the height sensors, make sure they are attached properly, etc.
Old Jun 4, 2021 | 02:30 AM
Alex J's Avatar
If they replaced your probably original Hitachi brand compressor with an updated AMK the vehicle will need a software update for the AMK compressor to work. I would also try to get your original compressor back and rebuild it and keep it as a spare if it hasn't gone to the landfill yet. Lots of DIY instructions on how to do this. If you verify that they did put the new style compressor in you might just want to go to another shop or the dealer and have the software update performed to see if that gets rid of the warning and makes the compressor work.
Old Jun 4, 2021 | 05:55 PM
houm_wa's Avatar
This ^^^ is a good point! It may have gone from Hitachi to AMK.
Scott Vernon
Jun 17, 2019 06:04 AM
andresatp
Apr 17, 2016 01:06 PM
ssrhythm
Jun 5, 2015 02:02 PM
tlawrence62
Jul 16, 2011 08:15 AM
Princess
Jul 8, 2009 12:34 PM
