Air suspension problem driving me crazy
Today it saved me money again, I used it to program a new key FOB.
I think that the use of the real-world values is where the designers of the Foxwell have gone wrong. It seems like every other tool simply allows you to input the arbitrary numbers that represent something to the LR's computer. It seems like from what I have seen on youtube that the best way to get it right is to just play with those numbers, but i am waiting to recieve my new tool in the mail for now.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
So just to be clear, you can calibrate the air suspension and program keys with this?? If so can you post some screenshots?
We aren't "probably" right, we are 100% right. That is where the "Cross Articulation" Fault is coming from. It doesn't mean there aren't other things potentially happening but the calibration is what's dropping you down at speed and also may be why your compressor is working harder. I'd fix it sooner rather than later.
I ain't mad atchya....some people have to learn the hard way, and that's okay. It's your journey.
People have used the RSW tool before. I'm not sure how good or bad they are....hopefully enough people on this forum have one such that you can get some help if needed. As for that Autel...I really can't imagine it being able to calibrate the EAS or do much else besides read codes. Something is fishy there.
Wow, this seems too good to be true. I have a friend who has a traditional Autel scanner. We tried it but it doesn't have that advanced of options. It reads all the air suspension codes, but I cannot calibrate or do anything quite that fancy.
I'll plug it in tonight or tomorrow and show you some screen shots of the interface. It's got a pretty thorough diagnostic side as well as what it calls a "service" side which would be what you're wanting to use.
What's fishy is that we don't all use this tool instead of some $539 dollar tool. Maybe there's SOME function it doesn't do or doesn't do as cleanly but for everything I see folks talking about, it does it. I've got my new programmed key in front of me right now and I drove it today using it, locked the doors, even programmed the 3rd button to unlock the tailgate.
...have you actually done an EAS Calibration with it?
...can you save a raised or lowered EAS setting with it?
...I won't even ask about CCF stuff.
Hey programming a key is a win! You made your money back right there. Calling it "fishy" isn't a call-out directed at you; I'm sure it says that, the Foxwell does too. If you haven't actually done it, then that **** is just words.
Anyway....rant over.
Alright, So I have a little bit of an update for you guys. In summary, I calibrated the truck and I am still getting the same issue...
The details:
The RSW Solutions tool arrived today. It was really simple to get working and I have no arguments against the software. it seems to work smoothly. Yet, the calibration is not as straight-forward/guided as it is on the Foxwell or the Autel AP200. Yet, did order an AP200 (with one-day shipping from Amazon Prime) and it is an amazing tool for the money. It can do all the same things as the Foxwell could. The problem I have with the AP200 seems to be Bluetooth related. I cannot get through a calibration without the tool disconnecting from my phone via Bluetooth.
Therefore, the fact remains that the RSW tool has actually been able to '"calibrate" my air suspension whereas the other 2 have not. As a side note, I may try to get another AP200 tool as it has a lot of features that I like in a scanner for other vehicles I work on (in case it is just a defect with the one I got). Also, it kind of fills the gaps in the RSW solutions software.
Alright, I will move away from tools and focus on the problem. I have now adjusted the suspension with the RSW to be very close to level side to side, but not front to back (~19" in front ~20" in back). One thing that is interesting is that when using the RSW to calibrate is that it does not put the vehicle into calibration mode as the other 2 scanners did. RWS solutions video just says to set the truck to 'normal' height and then measure. After each adjustment, I would lower and then raise the suspension and found that driving the truck a couple of meters forward and then back helped to get things to the set height. After doing this and getting it to be very close to the values I noted above I test drove it
and I still get the same result as before
. Around 40 mph I get an air suspension error. the only code I got at that point was for cross-articulation. So, maybe I am just not calibrating correctly... I don't understand why I would be getting an error code if everything is good and the sensors are now calibrated so that selecting normal height gives me a level ride
So any tips on how to calibrate with the RSW?
Do I need to aim for a certain ride height when the vehicle is set to "normal"?
Should I put the truck into tight tolerances mode for the calibration?
Have I thoroughly annoyed all you IIDtool owners yet?
Or am I just annoying myself...
The details:
.So any tips on how to calibrate with the RSW?
The details:
The details:
