Amp swap
Old Sep 18, 2019 | 07:02 AM
Inspector Morse's Avatar
Default Amp swap
I suspect my radio amp is shot. Head unit responds, just no sound on any setting. Is this a simple swap or does a different amp now need to be flashed by the dealer or something?
Old Sep 18, 2019 | 11:10 AM
abran's Avatar
Plug and play.
There are 2 kinds, best to remove yours first to match numbers.
Old Sep 19, 2019 | 03:22 PM
DakotaTravler's Avatar
^ What he said. I did some amp work and all it well. No reprogramming needed but you *may* want to swap with the battery disconnected to be safe. Also when removing the amp, careful not to unplug the seatbelt sensor (two wires) and power the vehicle up. If you do you will get a permanent SRS fault which you need an LR centric tool to clear (GAP tool, etc).
landy_ala
Nov 19, 2023 12:14 PM
tsalley
Mar 2, 2013 12:02 PM
cardinal77
Dec 2, 2011 06:10 AM
s928s
Audio/Visual Electronics
Oct 28, 2008 02:54 PM
