Any luck with eBay fob and IIDTOOL?
Old 02-03-2019, 09:09 AM
abran's Avatar
Yeah, links. And thank you for sharing. I’ve got an LR4 waiting for me me to finish a 300tDi swap on a defender so I can slap a motor in it that needs an extra key.
  #22
Old 02-03-2019, 10:07 AM
Received 1,513 Likes on 1,240 Posts
The other question is did he program the newer style to the LR3. I need a shop, but I want it without the hassle of customers
  #23
Old 02-04-2019, 08:49 AM
James Felix's Avatar
Default link to keys
Have any links to the keys you tried specifically the newer style?
These both worked on my 2011 LR4 with IIDtool BT. Interesting that these 2 keys worked perfect, and the IIDTool finished by saying Successful, and the 2 OEM used keys I tried ended up working but the IIDtool said they failed. Anyway now the Tool says I have 5 keys programed, 2 Old original and 1 of each from the links below, and 1 key that is lost is still programed to the car. I wish there was a way to remove keys too.
https://www.ebay.com/itm/Modified-Sm...72.m2749.l2649
https://www.ebay.com/itm/Replacement...72.m2749.l2649
  #24
Old 02-04-2019, 09:37 AM
Had me all excited, thinking you added the better looking newer keys to a LR3
  #25
Old 02-04-2019, 05:43 PM
DakotaTravler's Avatar
There is a way to re-program all your keys. I think it may be a dealer only option. That way any keys wondering around are no longer any good. I think I may have actually read that in the manual, I forget.
  #26
Old 02-05-2019, 11:32 AM
abran's Avatar
Can you explain the process you used to code these keys? Did you do the new aftermarket ones first? Or did you try the original ones first? Please share.
  #27
Old 02-05-2019, 09:12 PM
Default Keys
i bought the LR4 and it only had one key, so I first bought 2 used original 315mhz keys from LR4’s. I used the IID tool and used the Add a key feature and followed the process, it walks you through the process in ahoy 1 minute. To use this feature of the tool from the mail menu select Service/test, then BCM-Body control then Add a key. I followed the same process from for the cheap Knock of keys too.
  #28
Old 02-06-2019, 06:54 AM
abran's Avatar
Thanks, So the used keys coded as well?
  #29
Old 02-06-2019, 07:58 AM
Default Keys
Yes all the keys programmed properly
  #30
Old 02-06-2019, 12:35 PM
abran's Avatar
killer. I think the act of replacing the KVM which is the way the dealer does it is the only way to get rid of the old keys.
Bogwhoppit
LR4
15
01-16-2021 08:22 PM
earlyrover
11-14-2019 06:56 PM
tbdiscovery
02-16-2016 04:35 PM
foobar
07-04-2015 11:35 AM
bballjames
04-09-2013 10:51 AM
Quick Reply: Any luck with eBay fob and IIDTOOL?
