Anyone ever install/ repair a tccm on an 06” disco3
Old Mar 9, 2020 | 02:07 PM
Ilea Moore's Avatar
4wd High
Default Anyone ever install/ repair a tccm on an 06” disco3
Has anyone ever had luck in cleaning up corrosion on a tccm ? Or just replacing the cabling ?? I’ve found a new one but Before I send off 300$ I’d like to know if its something I can clean up using electric cleaning solution in the box and wires connector .
or how hard is it to install?? I have a ODM computer for my truck to remarry the new one . Are there any other steps I should take ? My terrain response is off and the computer says the monitor is bad . Any thoughts would be great thanx !
Old Mar 9, 2020 | 04:33 PM
DakotaTravler's Avatar
I repair vinage Mac computers. White vinegar works well to remove corrosion. Soak for about 10 minutes and use a tooth brush to clean. Repeat as needed. Rinse with alcohol.
Old Mar 10, 2020 | 11:56 PM
Globetrotter448's Avatar
+1 on the vinegar
3rd disco
Mar 25, 2016 12:54 PM
Chrisinhouston
May 2, 2010 09:15 PM
aussiedg87
Mar 5, 2009 11:26 AM
okdiscoguy
Oct 15, 2007 08:56 PM
