Battery disconnect switch - thoughts?
Old Jul 19, 2016 | 11:50 AM
tnk's Avatar
tnk
Default Battery disconnect switch - thoughts?
I was thinking about installing this switch from amazon or something similar. Anyone have any experience with these or do I need to steer clear? Just thought it would be a handy thing to have, and to keep from pulling fuses when lifting the truck, etc.
Old Jul 19, 2016 | 02:14 PM
houm_wa's Avatar
Seems pretty harmless and conceptually simple...but you may want to check the shape of that terminal and how to connect it to our cables. I feel like the shape of the LR3's cables and terminals are kinda funky....go figure.
Old Jul 19, 2016 | 02:49 PM
Zelatore's Avatar
I don't think there would be any problems with it, the only possible issue is making sure it will fit. Worst case you're only out $10 so no big loss.
Old Jul 21, 2016 | 11:44 PM
bbyer's Avatar
Default would not do it
The electrical is so touchy on these 3's that I tend not to change anything for the "better" unless there is really a good reason.
I did the Traxide second battery install thing but that is it. The second battery has the Anderson PowerPole inline cable disconnect between the two batterys that I disconnect prior to it going into a mechanics shop as they would not notice the second battery fully hidden under the second lid.
PowerpoleŽ Stackable Connectors, Anderson Power Products
I do carry a 13? mm wrench with me in the truck so I can disconnect the negative of the main as that is the safest cable to routinely remove.
To be totally accurate, I did use one of those disconnects on the negative side of the Aux battery where the ground cable attaches to the body sheet metal but have never had occasion to use it. It seemed like a good idea at the time but instead I just disconnect the Anderson on the hot side.
Note the inconsistency - I disconnect at the ground post on the Main but the hot cable on the Aux - go figure.
DISCO3.CO.UK Photo Gallery - Traxide Dual Battery install in LHDrive
bigbalu
Dec 4, 2014 02:13 PM
robgusto
Nov 12, 2011 08:57 AM
BFox15
Aug 3, 2011 06:47 PM
tsuami1
Jul 1, 2010 07:02 AM
josemex
Dec 20, 2009 08:38 PM
