BG Induction Service
Old May 8, 2014 | 10:52 AM
houm_wa's Avatar
Default BG Induction Service
....who's done it, and what were the results?
Recommend? Why or why not? Thanks in advance...
Old May 8, 2014 | 11:13 AM
jafir's Avatar
I did the injector cleaner. I didn't really notice much difference, but that could mean that my system was already maintained pretty well.
I HAVE noticed a difference in other vehicles that weren't very well maintained.
Old May 8, 2014 | 01:52 PM
houm_wa's Avatar
Thanks Jafir....no random faults or CELs or anything after?
Old May 8, 2014 | 01:56 PM
jafir's Avatar
Nope, not for me. I will say that the engine needs to be running on all 8 cylinders and needs to be pretty hot for it to run on the cleaner. I had one or two of my BRAND NEW ignition coils go bad when I attempted the cleaning and it just wouldn't run off the cleaner. I found the misfires and swapped a couple of spare coils and then it ran fine.
Old May 8, 2014 | 01:58 PM
houm_wa's Avatar
Did you do the service yourself?...like in your garage?
Old May 8, 2014 | 02:04 PM
jafir's Avatar
I did it in the drive way, in case it caught fire, I'd still have a place to sleep that night
I bought one of these:
Amazon.com: Dorman 800-131 Spring Lock Fuel Line Connector: Automotive Amazon.com: Dorman 800-131 Spring Lock Fuel Line Connector: Automotive
One of these, although it was a lot cheaper:
Amazon.com: OTC 7448 Fuel Injection Cleaner: Automotive Amazon.com: OTC 7448 Fuel Injection Cleaner: Automotive
and I had a harbor freight master fuel test kit. The quick connect fittings in the HF kit ARE NOT the same as the OTC can and hose, although they look similar, but I was able to swap a fitting from the HF kit to the hose on the OTC can. The HF kit contains a Ford style fitting that you should be able to use in place of the doorman part I bought, but in classic cheap tool fashion, it did not fit correctly.
For the price of all that stuff I bought, you could probably just get the Can and a single ford style fitting from the BG dealer. But I bought some of the stuff over time for other reasons, so for me it worked out cheaper for the individual purchases.
Old May 8, 2014 | 02:21 PM
jafir's Avatar
Here is a good video:
I don't like the way he took the hose apart, just because I priced the hose, and if it starts leaking afterward, it's pretty expensive. So that's why I bought the ford adapter and just removed the supply line.
thorgal
Jul 4, 2013 07:53 AM
armyproud
Apr 25, 2008 07:44 AM
Phototone
Apr 23, 2008 07:48 AM
Scanner
Mar 24, 2008 02:10 PM
utunes
Mar 24, 2008 10:27 AM
