On board air compressor LR3
Old Feb 14, 2014 | 01:51 AM
  #21
spiderman's Avatar
Originally Posted by unseenone
If you are putting on an ARB bumper and winch, I suspect it would support the winch with the compressor... did I miss something.
the ARB bumper for the LR3/4 may provide enough room for the Powerplant you speak of, but (in my opinion) that is only because WARN offers a new 9.5 size. The original size (perhaps 12?) was far too big for the bumper and unnecessarily WAY oversize for an LR3/4.
Here is a link.
Warn Industries - Jeep, Truck & SUV Winches: PowerPlant 9.5
The attached thumbnail shows the ARB Application Guide for LR3/4 and it says that 9500lb winches fit. Does that include the Powerplant's larger dimensions? perhaps more research is necessary.
Old Feb 14, 2014 | 08:17 AM
  #22
jerdog53's Avatar
Originally Posted by EAS
Much appreciated suggestions!
I worry about recharging the tank in rural Mexico.
Any dive shop can refill these
Old Feb 14, 2014 | 11:19 AM
  #23
EAS's Avatar
EAS
Here is a link.
This was the first off-the-shelf solution I explored. I checked with ARB and they said there is no way to fit the Warn winch/compressor combination. ARB said the bumper could not even be modified for the larger winch/compressor units.
I expect to install the ARB LR3 bump bar, LED lights, and Warn winch, but the compressor has to be a separate installation.
Yes, but I figured that gas stations were more numerous than dive shops in Mexico, so the compressor edged out the CO2 tank.
Old Feb 14, 2014 | 10:12 PM
  #24
spiderman's Avatar
Good to know. I would have looked into it myself, but I already own a winch and I plan to install it in a new ARB bumper this summer. I also plan to take a bit of time to design and build my own steel rear bumper. I have looked into some options and the Kaymar doesn't look to be worth shipping from Australia (if they even make it anymore).
Old Feb 21, 2014 | 05:16 AM
  #25
Absolut-land's Avatar
7th Gear
Default retrofit windshield heater
Hello
I want to retrofit my windshield heater but some of the wiring in the battery JB was not present. There are not the wires :
-1- between the two mini fuses (30A) and the screen connecters left and right (passenger side for an RHD) I found the plug.
-2- the wire between the hevac unit and the relay (electric diagram).
behind the hevac unit there is an Brown wire. If I put an voltmeter into this Brown wire en the negative terminal I have 0.5V I switch on the windscreen If I swith off I have 0V. Could you confirm me it is the good Brown wire.
Some one have a detail junction behind the heavac unit there is not the wire
Could you tell me too where is the connect to the Battery Junction box. The central Junction box there too many wires I'm lost.
Thanks before
I hope that my english you will not be sick
Old Feb 21, 2014 | 05:18 AM
  #26
7th Gear
Oups I made a silly things sorry
Old Feb 22, 2014 | 05:15 AM
  #27
EAS's Avatar
EAS
Ahhh... a rear bumper! Can you provide any details or images?
Old Feb 24, 2014 | 01:47 AM
  #28
EAS's Avatar
EAS
Default Found it!
http://www.kaymar.com.au/catalogue/Catalogue.pdf
It gets interesting around page 115.
Attached Thumbnails On board air compressor LR3-screen-shot-2014-02-24-12.44.38-am.jpg
Old Feb 25, 2014 | 06:40 PM
  #29
spiderman's Avatar
I haven't been keeping up with the forum lately. I'm glad you found the catalogue as I thought you wanted details or images of what I was planning to build. I have not yet come up with any plans, not even a single measurement. I'm sure when the weather gets nicer and the snow disappears there will be a thread about this plan of mine.
ljdiscovery
May 28, 2014 09:46 PM
thospb
Jul 25, 2013 01:03 AM
mirrajumper
Dec 3, 2012 05:40 PM
LandRoverDiscoDos
Apr 7, 2007 04:49 PM
