Brake Cage ??
Old Dec 22, 2018 | 12:49 PM
cybercop's Avatar
Default Brake Cage ??
One of the guides in the brake cage, at least thats what I think it is called is seized.
What is this part really called and has anyone ever had this problem.
That part where red arrow is
Old Dec 22, 2018 | 01:11 PM
Jagfixer's Avatar
Double nut? Hold inner, loosen outer.
Old Dec 22, 2018 | 01:37 PM
OverRover's Avatar
That's called the caliper bracket and the guide pin is what’s stuck.
Just use a PROPANE torch (NOTHING HOTTER) for only a few minutes where the yellow arrow is.
It will free up and pull out with vise grip pliers.
Old Dec 22, 2018 | 03:01 PM
cybercop's Avatar
Thanks. I’ll give that a try.
Old Dec 22, 2018 | 03:47 PM
OverRover's Avatar
You'll get it sorted no worries.
I think you will be amazed at how easy the pin comes out once you apply some heat. It won't take much effort at all.
This "method" has worked on every vehicle I've had with this problem.
Old Dec 22, 2018 | 10:22 PM
cybercop's Avatar
Got it out. Got some pins and boots coming in so I can wrap this up.
thanks for the advise.
Old Dec 23, 2018 | 03:15 PM
cybercop's Avatar
Now I had a damn Rotor set screw seized in. Had to drill it out and I think I messed up the treads in the hub.
Do you really have to put that set screw back in, or once you get the pads and stuff in place its not necessary?
Old Dec 23, 2018 | 05:13 PM
abran's Avatar
not necessary
Old Dec 28, 2018 | 11:58 AM
cybercop's Avatar
Originally Posted by abran
not necessary
what I figured
Onlyrovers
Mar 20, 2019 06:39 PM
dawang
Oct 29, 2018 12:01 PM
LR03NJ
Jun 28, 2018 10:24 AM
FlyingZebra34
Nov 1, 2017 04:34 AM
ls1morethanyou
Apr 3, 2014 12:35 AM
