Broken Headlamp connector pin
Old Aug 24, 2014 | 03:11 PM
weberic3's Avatar
Default Broken Headlamp connector pin, thoughts??
Hello all,
first post, but been enjoying other's since purchasing my '07 LR3 HSE last summer!
So, here's my question:has anyone had a pin break on the male end of a headlamp assembly connection?
My front right blinker had been inop (complete with fast blinker internal indicator) for a few weeks and all troubleshooting in accordance with previous post has not helped. I then noticed this today (notice missing pin in attached photo):
Does anyone have experience or thoughts on soldering a new pin? Anything to help me avoid spending the few hundred dollars required to replace the entire headlamp.
Thanks much!!
Old May 3, 2019 | 05:45 AM
Wing's Avatar
3rd Gear
I have similar problem that the pin does not protruded long enough to latch the black plastic latch. I have replaced the black plastic latch after a second try as the first one got broken when I tried to latch it. However, the pin does not seem to protrude long enough to catch the latch when the door is being closed. I’m not sure is there only the metal pin or there is something on top of it like a plaster cap. However, as far as all the photos provided that I have seem. they all look like just a metal pin without any cap or extension. Any advice that I could get the pin long enough to work. Many thanks in advance.
Old May 3, 2019 | 07:53 AM
emerica243's Avatar
8th Gear
My 2009 Lr3 pinout looks completely different. If youre 100% sure its that missing pin thats the actual issue then you can twist that connector and pull it out for easier troubleshooting \ game plan forward. I have a bunch of pinless connectors in my plug that arent actually used. Which is why im asking you if youre sure that missing one isnt by design as theres nothing actually wired to that on the backside,
Old May 3, 2019 | 09:13 AM
DakotaTravler's Avatar
Are you sure its not just pushed in?
Old May 5, 2019 | 08:37 PM
Rufflyer's Avatar
The right hand turn signal is in connector C0011 pin #3 wire color green with white stripe. Ground wire is pin #12 and the wire color is black. Look at the Jack or plug and figure out which is which then go from there.
Hope this helps
Jeff
Old Dec 18, 2019 | 08:24 AM
Wing's Avatar
3rd Gear
I have the same problem too as the pin does not protrude long enough to latch the black plastic latch. I thought the pin was broken, but the photos that i have seen here seem to be the same. How to fix it?
Old Dec 23, 2019 | 10:11 PM
Globetrotter448's Avatar
Like has been said, make sure that is the troublesome pin, then check whether it has just pushed back in to the connector. There is a member on this or UK forum that sells the pins/sockets
Old Feb 29, 2024 | 11:42 AM
User001's Avatar
Hello everyone, yes, it's been 10 years, but I have the same problem)) Does anyone know what Pins we use in this connector? I know that the width is 2.3 and the length is 2.78.. but does anyone know the valid part number/serial number? thank you.
sidescrollin
Dec 16, 2021 05:15 PM
jigray3
Jul 30, 2019 07:52 PM
Craig Rode
Jan 22, 2016 10:38 AM
cappedup
Apr 20, 2015 09:21 PM
jigray3
Oct 1, 2014 07:32 AM
