Bumper coming off - what to do?
I have a washer tank or hose leak I can't find. I need to remove the front bumper to get a look at the tank, pumps, and hoses to see if I can fix it. While it's off I may as well install fog lights in the bumper. (I know I'll also need a new switch to get the front fogs to work.)
Any other work I should do while I'm in there?
probly gonna do this to ours in the spring, fog lights , need headlight switch for fogs, fog housings, trim rings , harness and the screws and speed clips to hold the lights in, the inside of the bumper is factory marked for the cutouts, foglights should plug in behind the pass side headlight , remove headlight you will see the plug
you need to remove the front flares to pull the bumper cover, might want to locate the special 2 piece fasteners they desintagrate
bcolins
May 10, 2011 11:09 AM
JBEGIN
Jun 7, 2008 08:42 AM
disco12
Off Topic
Feb 26, 2006 06:18 AM
