Can/Bus no communication issue
Old Sep 7, 2020 | 05:21 PM
Globetrotter448's Avatar
Just thinking out loud here - leave the cluster disconnected and disconnect the abs unit and see what resistance you get. It could be wires in a connector shorting. With all disconnected should see zero ohms.
Old Sep 7, 2020 | 05:49 PM
OwlRover's Avatar
7th Gear
Thanks, I’ll try that in the morning
Old Nov 3, 2020 | 06:24 PM
overlandrover110's Avatar
8th Gear
Hi - how are you getting on? I've got similar problems and looking to see where I should focus my efforts.
Old May 15, 2023 | 11:28 AM
triwyn's Avatar
Default My hero
Originally Posted by Globetrotter448
The voltages you are getting on the can buss indicates it is shorted. You are correct, if all is good it should be 60 ohms as you read 40 ohms that indicates a problem also. The resistors reside in two places - firstly on the instrument panel and the other end is on the ABS module. If you disconnect the plug to the ABS module you should read 120 ohms.
Here is a diagram showing pin connections - having problems attaching files
I've been creeping around these forums for over year. I made an account moments ago solely to thumbs up this post. Having all this info on one sheet is legendary.
Thanks you!
angrylobster
Jan 4, 2024 12:40 PM
billypunk13
Dec 25, 2019 09:23 PM
billypunk13
Dec 24, 2019 06:22 AM
flwoodsman78
Aug 25, 2016 09:44 AM
awolrover
Oct 18, 2007 06:59 PM
