Can/Bus no communication issue
Just thinking out loud here - leave the cluster disconnected and disconnect the abs unit and see what resistance you get. It could be wires in a connector shorting. With all disconnected should see zero ohms.
The voltages you are getting on the can buss indicates it is shorted. You are correct, if all is good it should be 60 ohms as you read 40 ohms that indicates a problem also. The resistors reside in two places - firstly on the instrument panel and the other end is on the ABS module. If you disconnect the plug to the ABS module you should read 120 ohms.
Here is a diagram showing pin connections - having problems attaching files
Thanks you!
