Can't find trans Filler plug!! HELP!!
Old Jan 25, 2020 | 11:05 AM
Arlene Hinojosa's Avatar
4th Gear
Default Can't find trans Filler plug!! HELP!!
I've been going from forum to forum to find some kind of diagram to find the filler plug. Already drained the trans fluid but now I can't find which is the filler plug. I see a couple of plugs but not sure which one it is.
Old Jan 25, 2020 | 11:14 AM
5280LR3's Avatar
It's a round headed plug on the right (passenger side) of the transmission. It's just above the pan and has a 8mm allen head. Make sure to search the forum for the proper filling method.
Or search the web for "Land Rover 6HP26x Transmission fluid level procedures" which will take you to another forum where the .pdf resides
Last edited by 5280LR3; Jan 25, 2020 at 11:20 AM. Reason: added search info for fill procedure
Old Jan 25, 2020 | 05:57 PM
DakotaTravler's Avatar
Passenger side if LHD, just to clarify that a little.
This PDF will help you.
Old Jan 25, 2020 | 07:36 PM
5280LR3's Avatar
Default Another copy of the fill procedure
here is a copy of the procedure I was referring to...
Old Jan 30, 2020 | 05:58 PM
zski128's Avatar
Good tip when working on something that needs a fluid change (diffs, trans, etc) always locate and make sure you can remove the fill plug before you remove the drain plug.
Externet
Jun 6, 2019 03:25 AM
jonesy-1
May 23, 2019 10:14 AM
Snafu / Disco Fries
May 9, 2011 07:56 AM
josemex
Jul 31, 2009 09:58 AM
lhgdale
Dec 28, 2008 08:38 PM
