Can't get blend door motor installed: How to rotate it?
Old Nov 24, 2019 | 11:45 PM
PedalToTheMetal's Avatar
6th Gear
Default Can't get blend door motor installed: How to rotate it?
I managed to remove the two air blend motors, but now struggle to re-install one of them.
The motor I have sits in a position that does not align with the key on the shaft of the blend door. I am therefore not able to install the motor, unless I find a way to either rotate the motor's shaft of the flap door and to keep it in in this position until I have the motor installed.
I'd appreciate any ideas!
Old Nov 25, 2019 | 02:39 PM
abran's Avatar
Possible to plug in and actuate via the controls on the dash while its not mounted?
Old Nov 26, 2019 | 02:58 AM
Globetrotter448's Avatar
One makes the assumption that it is a identical replacement
Old Dec 24, 2021 | 09:14 AM
The_OGCJR's Avatar
I know this old but I have this problem as well
did you fix it?
ljdiscovery
Apr 22, 2025 07:59 AM
bigjerel
May 1, 2017 12:33 PM
JamesDisco97
Feb 14, 2014 11:11 AM
04BluDisco
Jul 11, 2011 11:58 AM
base
Oct 7, 2009 12:43 PM
