cd player won't load
Old Jan 21, 2008 | 09:46 PM
fishnchips's Avatar
5th Gear
Default cd player won't load
Hi,
I just bought a used LR3 SE and the one thing that I didn't check is whether or not the CD Player would load. Turns out, it won't. I tried loading one at a time and hitting the "load all" function (and selecting it through the menu), but I'm getting nothing. It says loading for a fraction of a second and then "No disks". Anyone had this problem and know of a solution (besides buying a new head unit)?
Thanks.
Old Jan 22, 2008 | 06:38 AM
drzjoint's Avatar
Default RE: cd player won't load
i just figured this out 2 days ago i had the same thing
i thought somthing was stuck
you have to select which cd number you want it put into
so select into the cd and then push 1 on your preset and insert the cd
then for the next cd select 2 up to 6 cd's
it will pop up load disc
if that dosent make since let me know and i will go out to the car wheni get home and go thru the sequenceand explain it again i just figured it out 2 days ago i hadent put a cd in since i had bought it until sunday when i thought i havent tried the cd player yet when i was running some erronds so i bought a cd and figured it out
also check your manual it should be in their if you dont have one you MUST get one
check e bay or call who you bought it from and track it down it is a must
have in you vehicle at all times. ther are sequences you must go thru in order to start the vehile after an accident so it is a must have and im not a munual guy i just figure it out
but you need it on this vehicle
Old Jan 22, 2008 | 06:15 PM
fishnchips's Avatar
5th Gear
yeah, i tried that and it says "loading" for a split second and then it goes back to "No Disc, Select 1-6". It's pretty frustrating, but I've got it at the Land Rover tech today, so I'm hoping that they can figure something out. I really don't want to have to hassle with the dealer again to get money for it (since it's used and out of warranty). I'd rather it just work...
Old Jan 27, 2008 | 08:02 PM
fishnchips's Avatar
5th Gear
FYI - I took it into the local land rover shop (Rover Techs in Arizona), and all they had to do was hook the head unit up to a computer and reprogram it. Apparently, they sometimes get messed up when the battery runs out and have to be reprogrammed. Beats $700 for a new head unit. If this ever happens to you, just call around to see who can do it.
WaltNYC
Apr 12, 2012 11:00 AM
discoverysan jose2
Jul 6, 2007 09:28 AM
Jeffrey
Mar 9, 2006 04:02 AM
wbudna2
Jul 1, 2005 11:21 AM
