CEL but no faults found in GAP?
Old Dec 12, 2023 | 07:31 AM
lasoundguy's Avatar
Question CEL but no faults found in GAP?
Hi there. Our LR3 threw a check engine light over the weekend...no recent work apart from an oil change maybe 500 miles ago. I plugged in the GAP tool and pulled faults, but no faults were found.
Then I tried checking some live values and I noticed it's not reporting oil or coolant temperature in the Live Values section (it used to.)
Anyone run into this before? Any ideas of next steps? Seems to be running fine FWIW.
Thanks!
Old Dec 12, 2023 | 11:14 AM
douglastic's Avatar
If you see a check engine light, there should be a code.
Is the light still on? Try again?
Old Dec 12, 2023 | 07:18 PM
lasoundguy's Avatar
Finally was able to pull the codes and live values after pulling the GAP tool out, starting and shutting down the truck, and then reseating the GAP tool. Looks like it's a PO420-00 (catalyst system efficiency below threshold (bank 1)) error so for now I will ignore and see if it comes back.
thanks.
Old Dec 13, 2023 | 10:42 AM
Gordo51's Avatar
I have had that code several times on my 2008 L322 and at least once in my 2008 LR3. I just clear it. Seems to have no effect on engine performance. I wonder what exactly triggers it? Must be something to do with the downstream O2 sensor.
Old Dec 13, 2023 | 12:29 PM
abran's Avatar
It’s telling you your cat on that bank is not working properly.
Chris Erke
Nov 10, 2019 12:03 PM
Philip Chan
Jun 21, 2019 11:23 PM
djkronik57
Nov 13, 2017 04:55 PM
