CEL on my '06
Old Nov 10, 2020 | 11:24 AM
houm_wa's Avatar
Default CEL on my '06
Hi all,
2006 HSE, 204k miles on the clock.
Started it up the other day, first legit cold morning in western WA state (around 32F) and was greeted with a CEL icon. The display said something like "Engine System Fault" not sure the exact syntax because as I cycled through it, that message was gone. I drove around, didn't go away. Cycled power, didn't go away. Drove fine. No symptoms at all.
So when I got home I plugged in the ol' IIDTool. It stated the following under the "Engine Petrol" category:
P0018-00(A8) Crankshaft position - camshaft position correlation - bank 2, sensor 1
I cleared it, and haven't seen it since. I am chocking it up to some phantom sensor snafu based on cold weather.
Has anyone seen this before and/or have any insight?
Thanks in advance,
Houm
Old Nov 12, 2020 | 09:53 AM
jagmandan's Avatar
Never seen it, but as it seems is your plan, I'd be inclined to just clear it and see if it comes back as a start.
Old Nov 13, 2020 | 03:39 AM
Globetrotter448's Avatar
I have had that a couple of time on my 2007 V6 petrol but have not seen it since I replaced the battery that died.
Old Nov 13, 2020 | 07:33 PM
houm_wa's Avatar
I'll check that battery, thank you...
Old Nov 20, 2020 | 09:40 AM
Rufflyer's Avatar
Slow (cold) oil supply to Vanos causing a variation that exceeds the tolerance for just long enough to trigger a CEL?
But , that should have gone away once it warms up.
So still thinking about it.
Sorry not much help on this one.
Jeff
Old Nov 20, 2020 | 10:26 AM
houm_wa's Avatar
That's alright....I checked the battery and it was indeed a bit low. 12.0V and it had been driven the previous day. I've only had this LR3 for 1.5 years so the battery is at least that old. I'm not sure when the PO installed it and the markings on the battery indicating the date of install are inconveniently covered by the tie-down bar. I'll put it on the list!
Explorer0863
Apr 26, 2017 06:34 AM
RoRoRover
Dec 20, 2013 08:07 AM
cabucky
Dec 14, 2013 03:32 PM
Outback Jim
Jun 22, 2010 09:14 AM
adamsdisco2
Jun 2, 2009 12:00 PM
