Key Stuck in Ignition
Old Nov 17, 2020 | 12:08 PM
Jennifer Fox's Avatar
Default Key Stuck in Ignition
Hi!
My key / key fob are stuck in my ignition! I can’t remove the key.
We have tried everything! Jiggling the key a million times, turning the wheel, pushing the auto gear shifter further into park, rocking the car back and forth..... I am going crazy!
Any tips for a diy so I don’t have to hand over all my money to the shop?
Thanks!
Old Nov 17, 2020 | 02:59 PM
pagoda's Avatar
Does the vehicle start? If so, can you shift from park to drive and drive the vehicle? It could be that the vehicle isn't engaging park correctly, which would lock the key in the ignition.
Old Nov 17, 2020 | 03:44 PM
I can drive it, it drives great. I tried pushing the shifter hard into P but the key is still stuck! I am still driving it but just leaving the key in when I park.
Old Nov 17, 2020 | 07:37 PM
pagoda's Avatar
I think that park isn't aligning. Disconnecting the battery and doing a hard reset may work. Read this; may help: https://www.disco3.co.uk/forum/topic92358.html
Old Nov 18, 2020 | 08:41 PM
DakotaTravler's Avatar
How about when in neutral? My guess is the key interlock is broke.
Old Nov 21, 2020 | 02:06 AM
Johan Roelofse's Avatar
5th Gear
Im was stuck, did a hard reset with terminals and it came right out.
Gabb3r
Jan 18, 2019 08:52 PM
wastedincome
Oct 20, 2012 06:02 AM
elpapisf
Apr 18, 2012 06:19 PM
proto47
Oct 2, 2010 01:16 PM
Kraftyz51
Nov 2, 2008 11:46 PM
