Centre console problems
Hi All. Looking for some very much needed help before i completely lose it..... any assistance would be very much appreciated.
Had my LR3 for a couple of years now and after it developed an alternator problem (red battery light on dash drama) it's all good once again.
However.............the hazard lights work, the indicators all flash but the actual button on the console no longer flashes. Not the end of the world but .... i replaced a while back the OEM cigarette lighter panel with Tuff-Rok's voltage display, USB charging ports etc which has also ceased to work. But the biggest grievance i have is that the stereo no longer works. I replaced the OEM with a Kenwood double DIN and had it wired by Halfords (the new unit didn't receive any power so it's direct from the fuse box). The unit iteself draes some power as when you press the CD eject button you can hear a whir but it did that before i got it wired correctly.
I have yet to check if the rear 12v output in the boot is still working... no that it's needed but if it's part of the problem as well it may (or may not) shed some light in the issue.
As i said, any pointers would be very much appreciated.
Regards,
Chris.
Regards,
Chris.
This may sound funny but; make sure all of the connection on HVAC unit are plugged in well.
There was a thread about the radio not working and the flasher coming on for no reason and some other stuff that was related to the HVAC controller. I will look for it.
Jeff
Jeff
The button never flashed. There is no light behind the hazard button switch. As for the other stuff, guess you need to pull it all and look. If HVAC panel is not plugged in (three connectors) the truck will not even start.
Paul Streicher
LR2
36
Mar 3, 2020 08:08 AM
