cheap snorkel
Old Aug 3, 2017 | 10:05 AM
  #41
cmb6s's Avatar
Yes, that’s the same problem I had with mine. Ultimately, I ended up dremeling the slot in that upper bracket to extend further down (and possibly to the side). I also put a little bit of green felt with a sticky back underneath the top half of the bracket. The problem is that the bracket wasn’t even angled correctly, which put a lot of stress/strain on that mounting point. The last time I torqued it down, it loosened the Riv-nut. So… now I’m not sure what to do, but I may have to end up using some JB-weld on the Riv-nut. I’ve done that before with success… I guess I could drill it out and install a larger one too, but the point is that I think I’m going to rebend the upper bracket so that it sits at a better angle with the body.
jeffh
Jan 29, 2011 09:58 PM
Chris528
May 7, 2010 08:37 PM
tallalien
Feb 16, 2009 01:37 PM
Wanix
Oct 16, 2008 05:39 PM
PRED8TER
Jan 5, 2007 03:29 PM
