Check Engine light = CATS
Old 02-11-2021, 03:13 PM
Husker's Avatar
Default Check Engine light = CATS
So my CEL light is on, and my mechanic says it is due to the catalytic convertor(s) gone bad. He said it is crazy expensive to replace this. Is there a work-around on this so I can get the CEL light off? Smog tests aren't an issue in Texas.
Old 02-11-2021, 03:54 PM
houm_wa's Avatar
Does this mean you don't have an IIDTool to check on the condition yourself?
There are extensions for the O2 sensors you can get; that could be a work-around. I wouldn't do it, but....you might.
Old 02-11-2021, 04:57 PM
Husker's Avatar
Talking
That's correct, I don't have a tool. Frankly, this is a $5000 car, so I don't mind doing work arounds to get the CEL light off. I've told my daughter that if your temps are OK and the tires have air in them, don't worry about it.
Patrick Desmond Maher
11-08-2020 05:08 PM
earlyrover
07-13-2013 07:25 PM
'BamaBoy
05-24-2012 12:45 PM
Classic89
05-17-2008 08:56 AM
Range98Rover
11-08-2005 12:42 AM
Quick Reply: Check Engine light = CATS
