Chips in Radiator cooling fan
Old Mar 22, 2015 | 01:32 AM
Delray's Avatar
Default Chips in Radiator cooling fan
I just changed out a bad pulley today, and when I was trying to remove the fan bolt from the fan pulley, the wrench slipped a few times and broke a small corner of a fan blade. As I rotated the fan around, I noticed two other blades with similar size chips in them. The chips are maybe an inch off the very end of the blades.
Is this going to cause any problems? I am not noticing any noise or vibration indicating balance issues with the blade.
Old Mar 31, 2015 | 08:24 PM
unseenone's Avatar
I would recommend replacing it. There is a good chance the blades could explode all over the place if they are damaged.
Old Apr 1, 2015 | 11:13 AM
Racer X's Avatar
Exactly this. Which will in turn perforate your radiator.
midessa7
Oct 13, 2008 07:36 AM
markroll
Mar 12, 2008 09:36 PM
NWDiscoRover2004
Jul 23, 2007 07:25 PM
rookshark
Defender
May 8, 2007 05:33 PM
wildhorses
Nov 4, 2005 12:27 AM
