Coil Conversion Module Issue
Old Jun 24, 2025 | 03:45 PM
doodah92's Avatar
Default Coil Conversion Module Issue
I just converted my 06 LR3 SEV8 to coils and am experiencing an issue when trying to use my GAP BT device. Before I wired in the module I was able to see the blinking light on the tool but after install it doesn't flash and my app is not seeing it on BT. On the instructions it says to wait for the module to flash prior to starting the engine so I'm wondering if I didn't allow enough time to elapse and if so is there a way to reset so that I can go through that process again? I'm going to disconnect the battery and let it sit overnight then turn on the ignition and give it time before starting but wondering if I need to remove everything and start over, only concern there is the air is gone so I might get the fault codes and not be able to reset those. I don't use the GAP a lot but right now getting a check engine light and want to sort that before driving it too much, no suspension faults or lights are on so I assume the module is working. Anyone have experience with this?
Old Jun 24, 2025 | 06:48 PM
DakotaTravler's Avatar
It does nor matter when you plug it in, most of the time I use it I dont even turn the engine one to run certain things. Other times I do when not all the computers are online. My guess if you managed to blow the ODBII port fuse.
Old Jun 25, 2025 | 02:41 PM
doodah92's Avatar
Didn't even think about a fuse, I'll check that.
Old Jun 26, 2025 | 08:13 AM
doodah92's Avatar
fuse is good, and now the suspension fault is showing up. Back to the drawing board.
rob bartleman
Aug 6, 2025 01:34 AM
CagleRacing198
LR4
Apr 3, 2024 07:56 PM
sam4927
Feb 1, 2024 11:43 PM
toofaroffroad
May 19, 2022 10:16 PM
delormea397
Dec 18, 2018 04:55 AM
