Complete Flush Brake Fluid
Old Mar 10, 2012 | 06:56 AM
rzuluaga's Avatar
Default Complete Flush Brake Fluid
Hi guys,
I have a LR3 05 HSE and I will be doing a complete flush brake fluid. From all the information I have gathered I think the following are the steps I need to follow.
1- Engine on
2- Pump brake pedal
3- Engine off
4- Disconnect connector on top of brake fluid lid
5- Remove brake fluid lid
5- Fill brake reservoir with new brake fluid to Max
6- Close brake fluid lid
7- Connect a pipe on your RR bleed nipple to a empty container
8- Undo the bake bleed nipple
9- Gently press the brake pedal all the way down and let it return to the top several times
10- Make sure that brake reservoir is not getting empty
11- Confirm that new brake fluid is now going to the bleed container
12- On the last pumped brake pedal hold it down and then tighten bleed nipple
13- Let the brake pedal return to top
14- Repeat the same steps from 5 to 13 now with RL then FR and then FL bleed nipple
15- Connect connector on top of brake fluid lid
Am I missing something?
Am I doing something extra that is not needed?
Thanks in advance, Roberto
Old Mar 10, 2012 | 07:41 AM
Read my reply on the LRO
Old Jul 13, 2021 | 09:39 AM
artbenson's Avatar
I have an 06 LR3 SE. Can I assume the procedure is the same?
Old Jul 13, 2021 | 01:24 PM
douglastic's Avatar
I follow this guy's methods for brakes:
https://media.disco3.co.uk/gallery/a...le_V1.4sml.pdf
Speaking of, I am due again!
I use Pentosin DOT4 LV (1.5L)
MPDano
Jun 29, 2015 08:12 AM
SurfRat
Oct 14, 2008 02:51 PM
sdsilvere38
Sep 2, 2008 09:35 AM
mwyrick45
Feb 7, 2008 11:24 AM
loic
May 19, 2007 08:07 PM
