Cool packs
Old Mar 8, 2020 | 03:49 PM
Dre day Lr3's Avatar
Default Cool packs
Should I use a OEM from land rover or other cheap kind if I'm replacing one?
Old Mar 8, 2020 | 03:56 PM
DakotaTravler's Avatar
Cool packs? Do you mean coil packs? What engine? I know the 4.4 does not have coil packs.
Old Mar 8, 2020 | 07:26 PM
cmb6s's Avatar
You mean the 4.0 doesn’t have coil packs?
Old Mar 8, 2020 | 07:29 PM
Pretty sure I said 4.4. No clue on what engine the question pertains to.
Old Mar 8, 2020 | 08:30 PM
cmb6s's Avatar
Didn’t mean to be rude, but the 4.4 does have coil packs (unless I’m confusing my engines, but don’t think I am). I had to replace one after I was changing the plugs and the coil pack tip broke off and stuck on the end of the plug.
Part #4744015
Old Mar 8, 2020 | 08:31 PM
The 4.4 does not have coil packs, its has the COP setup. Coil-On-Plug. Individual coils, not a pack. A coil pack consists of two or more coils that are triggered to fire and the spark is usually on a spark plug wire - the 4.4 also has no spark plug wires.
Old Mar 8, 2020 | 08:42 PM
cmb6s's Avatar
I guess I’ve always referred to those “coil on plugs” as “coil packs”, and I believe many others do as well (whether right or wrong). Understand there are no plug wires per se as I haven’t seen a car with an actual distributor in a long long time.
anothersilver
Mar 22, 2019 09:16 PM
Luckyjayb
Jul 22, 2017 09:13 AM
aroshan
Jul 4, 2017 07:27 AM
Chrisw7562
Mar 2, 2017 08:47 AM
elboy0712
Mar 11, 2010 10:18 PM
