replacing individual coil packs
Old Mar 10, 2010 | 04:35 AM
elboy0712's Avatar
Default replacing individual coil packs
is there any reason that i should not replace individual pairs of coil packs or is it really necessary to replace the whole bank of packs
Old Mar 10, 2010 | 06:22 AM
Rovin4life's Avatar
if you can get them then go ahead. But don't assume that is the problem. I have seen a few ecus and fuel injectors cause the same issue.
Old Mar 10, 2010 | 08:13 AM
okdiscoguy's Avatar
pretty sure Autozone here sells the pairs separatley.
Old Mar 10, 2010 | 10:52 AM
What sort of problem are you having and how have you determined it is the coil?
Old Mar 11, 2010 | 03:19 AM
elboy0712's Avatar
Default misfire on cylinder 8
this misfiring only happens during warm up though once warm it stops. I also was pondering the engine coolant temp sensor but that hasnt gotten much play on here. also as a side note the rpms that te ecu are registering are higher than what the tach shows.... just a sidenote
replaced the wires with magnecors already and the plugs with new bosch fusions. cleaned the throttle body and replaced the fuel filter... done and induction cleanign and run drying agent through the fuel. replaced all 4 o2 sensors... kind of out of options.....
Old Mar 11, 2010 | 03:20 AM
elboy0712's Avatar
im thinking of swapping the coil pack for 8 with another one and seeing if the fault moves
Old Mar 11, 2010 | 07:55 PM
Robwsup's Avatar
I'm going to try the same thing. I have misfire on 3 and 7, both off the same pack.
Old Mar 11, 2010 | 10:18 PM
greg409's Avatar
Snoop around, I've read that other coilpacks are a bolt-in (mitsubishi 4cyl.?)
although new they're not cheap either, but you may find it used.
luck,greg
trialrun
Nov 11, 2014 08:41 AM
pinkytoe69
Jul 2, 2013 10:48 AM
moomoo
May 23, 2011 01:16 AM
meltdowndave
Dec 29, 2009 01:54 PM
03discoman
Apr 27, 2009 09:54 AM
