Is this a Denso MAF?
Old Feb 21, 2023 | 12:02 AM
HaSlEt's Avatar
Default Is this a Denso MAF?
The previous owner had the MAF replaced before I bought it, in the past 2 months. Long term Fuel trims for both banks are still around 10%, which means it is only a matter of time before the P0171 and P0174 pop up again. I've reset engine adaptations, replaced the VVTL gaskets, replaced the o-rings on the filler neck and oil cap, checked and silicone lubricated the PCV hose o-rings, permatexed the throttle body gaskets (both sides) and cleaned the throttle body. I also permatexed the EGR itself and its mating flanges.
I can't find any pictures of a DENSO LR3 MAF. It says made in China, but Denso does have some parts made in China. Does anyone know if this is DENSO or aftermarket? Also, what is the p/n of the DENSO MAF if this is not the denso one? Thanks.
Old Feb 21, 2023 | 07:03 AM
DakotaTravler's Avatar
No....
Old Feb 21, 2023 | 08:06 AM
Blackngold77's Avatar
Definitely no. Denso MAFs have name and part number stamped on the top
Old Feb 21, 2023 | 08:14 AM
SeattleDriver's Avatar
PHF000140
https://www.partsgeek.com/k78kjqg-la...ow-sensor.html
Old Feb 21, 2023 | 08:40 AM
HaSlEt's Avatar
Default Thanks All!
You guys are awesome.
Old Feb 21, 2023 | 08:42 AM
Can also use a Toyota Denso MAF on these (it's the same exact part), but I'd use the parts geek one above.
Just make sure it's at least $75 though, lots of knock offs on ebay for $20. Toyota part # is 22204-22010
Old Feb 21, 2023 | 08:10 PM
Well in fairness the knock offs can be priced high just to make people think they are legit. Just make sure you buy from a reputable seller.
Old Feb 21, 2023 | 08:47 PM
HaSlEt's Avatar
Can confirm that Denso dropped all fuel trims. Now around 3% LTFT from 10+% before.
Thealooox
Jun 21, 2022 12:02 PM
VCO
Oct 17, 2011 09:07 PM
Switzer
Jul 9, 2011 07:02 AM
Roverpatsfan
Sep 16, 2009 08:16 PM
jasons
Aug 11, 2009 10:09 PM
