Seized Pully???
Old Aug 20, 2017 | 02:26 PM
Bravhefen's Avatar
Default Seized Pulley???
My serpentine belt broke the other day. Got a new one and replaced it, but the new one smoked something awful and broke almost right away. I got my LR3 back home (on a tow truck) and now have removed the broken belt again. I checked all the pulley's and the only want that will not spin by hand is the A/C compressor. Is that normal or do I have a seized pulley?
If I do, what can be done?
Thanks for any help and input.
Old Aug 20, 2017 | 05:24 PM
abran's Avatar
If it won't spin you need an AC compressor.
Old Aug 20, 2017 | 05:35 PM
what he said sounds like the compressor froze up
Old Aug 21, 2017 | 06:19 AM
number9's Avatar
Could also be clutch pulley bearing seized. If clutch and pulley not damaged could be as simple as a clutch pulley bearing replacement, Complete clutch assemble can also be replaced without opening the system. DIY can often save the expense of replacing comp/clutch assembly and needing to have the system serviced. Bearing or clutch replacement is fairly easy depending upon access/location.
Most repair shops are going to sell/install comp and service your system and cost some large change.
ColoDisco
Apr 9, 2010 11:25 AM
Robeye
Mar 11, 2008 12:16 PM
DeepBlueWater
Nov 11, 2007 01:21 PM
kfordric
Jun 19, 2005 01:52 AM
kfordric
Jun 4, 2005 10:16 AM
