Downshift Jerk from 2nd to 1st
Old Dec 15, 2019 | 07:43 PM
  #21
loanrangie's Avatar
Proper fluid?
Also I think you can reset trans adaptations with the GAP tool. I won't speak form experience, but some are for and some are against doing this.
I did a reset and it was crap for a few days but then settled down, i use a local Penrite product developed for the ZF6-9. I know a few others including indies that use it as its 1/3 the cost of LG6.
Box has 187k klms on it and the previous one owner had the fluid and filter/pan done at about 120k, never used offroad and never towed more than a motorbike trailer, my symptoms lead me to believe that a sonnax zip kit plus mechatronic sleeve and other seals will help most of this.
Old Oct 12, 2023 | 06:01 AM
  #22
Landydude's Avatar
Default Loanrangie
Hey Loanrangie I know this is an old post, hoping you are still onboard. Did you ever install a Sonnax zip kit to solve your 2 to 1 transmission coastdown bump?? I have a 2006 RR Sport which shifts well except for the dreaded 2 to 1 thump driving me crazy. My Rangie has done 260000km. My research tells me Sonnax or Transgro shift kits and bridge seal etc will help but not spoken to anyone who has actually tried the kits on a ZF6HP26. I am based in country Victoria
Old Oct 12, 2023 | 06:17 AM
  #23
loanrangie's Avatar
Certainly did in April this year, sonnax kit,new solenoids and separator plate and its like a new trans. Cured all the issues i had with poor and erratic shifting and going into limp mode at the slightest amount of load.
Old Oct 13, 2023 | 08:48 AM
  #24
Landydude's Avatar
Default Sonnax Zip Kit
Thanks for the response! Assume you also have the zf6hp26 trans in your D3? Was the kit the standard zip kit incl new accumulators and end caps. Did you have to do any reaming of the valve body? I have been told need to ream out the solenoid pressure regulator valve. Would appreciate some guidance on where you sourced the kit, solenoids and seperator plate etc if possible. Thanks Nick
Old Oct 15, 2023 | 07:40 PM
  #25
loanrangie's Avatar
Yes the standard kit, if your bores are good then no need to ream as the new plungers have o-rings where the originals don't.
I got the kit from Alltranz in Thomastown and separator plate and solenoids off ebay.
okdiscoguy
Jan 16, 2024 04:31 PM
JUKE179r
Build Threads
169
Dec 29, 2023 05:49 AM
bull907
Dec 16, 2019 04:27 PM
GTFNK
Nov 11, 2019 10:22 PM
yorocky
May 17, 2014 04:55 AM
