Drivetrain noise
Old Dec 8, 2023 | 09:41 PM
  #31
DakotaTravler's Avatar
Someone recently bought the Parts Geek one and what came was very much an OEM GKN shaft.
Old Dec 9, 2023 | 01:47 AM
  #32
houm_wa's Avatar
It was....unfortunately though, installing it didn't make that rumble noise go away! I don't know what else to try. I fear it's the bearing in the T-Case, but don't know why the steering wheel input would influence that.
Old Dec 9, 2023 | 08:12 AM
  #33
james.martin1's Avatar
Originally Posted by kels83
Edit to add: bolts on the drive shaft are SAE for some reason. Using metric 6 or 12 point metric might work but risks rounding. SAE works great. Don't ask me how I know lol
I think these are normally e-torx bolts so maybe a previous owner had replaced yours with SAE hex? Also, IIRC the 4 rear bolts are torque to yield and should be replaced.
Old Dec 9, 2023 | 11:53 AM
  #34
houm_wa's Avatar
Thanks....did y'all catch the part about the driveshaft NOT being the source of my rumble/noise? I fear that it's the bearing in the T-Case....again.
Old Dec 9, 2023 | 01:25 PM
  #35
P-Bod's Avatar
Originally Posted by houm_wa
One more thought. The rear upper control arm bushings on the driver side are really shot.....could that be the culprit? Maybe the groan goes away in a left turn because the bushing gets compressed.....maybe?
You have a known problem here. The rubber bushing isolates the arm from the frame. 25 degrees steering is a lot. You may be floating the the bushing sleeve by turning that hard and eliminating the noise. If you can, maybe shove a piece of rubber in the bush to see if you change the noise without biting the bullet on a rear overhaul.
Just guessing on possibilities.
Old Dec 13, 2023 | 08:38 PM
  #36
Good video on rear driveshaft. Shows the issues with cheap versus GKN....
Old Dec 19, 2023 | 06:34 PM
  #37
houm_wa's Avatar
Default Update
The saga continues. After now having charge propshaft and both front hubs, rotated the tires...the rumble persists.
Noting that my tie-rod ends in front are a little worn and my rear upper control arm bushing is toast, what else could make a sound that is a dead ringer for a bearing? CV-joint?
I do plan on addressing these other items but I'm treating it like triage and want to at least get out of the woods because The rumble is getting louder and safety is becoming a larger concern.
Old Dec 19, 2023 | 07:05 PM
  #38
loanrangie's Avatar
What about the rear hub bearings ?
Old Dec 19, 2023 | 07:20 PM
  #39
houm_wa's Avatar
Those are next on the list. I had sort of ruled them out since the noise goes away in a (left) turn and the rear wheels don't turn....but they do get unloaded in turns, so I suppose it could still be a rear bearing, most likely the left.
Old Dec 19, 2023 | 07:47 PM
  #40
houm_wa's Avatar
So far I'm finding rear bearings sold as just that....in other words not the entire hub just the bearing. Is that the proper way to source them? Are they difficult to install? Is it important to replace the nut and circle clip as well? Are they the same part L/R or do I need to find two different parts? Much appreciated!
