Engine drive belts replacement advise.
Old May 8, 2018 | 02:26 PM
Athana's Avatar
Default Engine drive belts replacement advise.
Hi..Our LR3 SE 2006 needs new Engine drive belts.
Are aftermarket Gates Belts as good as oem?
If not which do you suggest.
Thanks
Old May 8, 2018 | 02:41 PM
houm_wa's Avatar
OEM belts are not very expensive...not sure why you'd go with some off-brand. You are talking about primary and secondary serpentine belts, right?
(not sure if there are any others)
Old May 8, 2018 | 07:26 PM
DakotaTravler's Avatar
I always go with Gates.
Old May 8, 2018 | 10:15 PM
abran's Avatar
No problem with gates here
Old May 8, 2018 | 11:06 PM
Gates are great belts
Old May 9, 2018 | 04:11 PM
Athana's Avatar
Drive Belts..Two Drive Belts at Land Rover parts department was $110 at one LR dealer and $140 plus tx at another.
The local mechanic is charging me $150 to do with Gates..sounds a good difference.
Old May 9, 2018 | 04:35 PM
OverRover's Avatar
Gates belts are my first choice 100% no matter what vehicle (that includes Timing belts). It's real simple for me, Gates Belts have proven to work without issue many times (30+ years). You will be glad you went this direction.
You got it done for less money and didn't have to compromise on quality.
Just a Headsup, NAPA sells Gates Belts as their private label brand = easy to get local!
Old May 9, 2018 | 05:26 PM
Athana's Avatar
[QUOTE=OverRover;647083]Gates belts are my first choice 100% no matter what vehicle (that includes Timing belts). It's real simple for me, Gates Belts have proven to work without issue many times (30+ years). You will be glad you went this direction.
Just a Headsup, NAPA sells Gates Belts as their private label brand = easy to get local! [/QUOTE
​QUOT
Thank you ..and everyone else.Will do.Many thanks.
Old May 9, 2018 | 11:50 PM
houm_wa's Avatar
I've had both serpentine belt done, at LR, and don't recall the price being that much. I could be mistaken as I had other work happening concurrently.
rovernoob
Mar 15, 2015 09:07 AM
seb1755
Jul 31, 2011 10:03 PM
onmy3rd
Freelander
Mar 26, 2011 11:35 AM
kyndrad77
Freelander
May 27, 2009 03:02 AM
evoking
May 25, 2009 10:47 AM
