Engine noises, possible timing chain issue
Old Jul 1, 2019 | 12:27 PM
Cjlr3's Avatar
Default Engine noises, possible timing chain issue
Hi guys,
LR3 is making two sounds:
1.) a rhythmic sound, loudest from the passenger wheel wheel, that sounds like a timing chain issue. It doesn’t seem to be a major issue, but it’s noticeable, like when idling in park or in drive thrus. I don’t know much about this issue, seems like the tensioner will sometimes need replaced–is this correct? If so, is this a DIY task for those that are handy?
2.) when idling in drive or reverse, I get a noise that sounds like a few raindrops here and there. It doesn’t sound like a tick or rod knock to me, more like something loose, but I can’t find anything. Curious what it could be, possible transmission issue?
Thanks, all.
Old Jul 1, 2019 | 06:27 PM
DakotaTravler's Avatar
1 - could easily be an exhaust leak.
The exhaust manifold bolts are known to come loose and cause an exhaust leak. Indeed noticeable in a drive-thru. I was able to access the back ones on both sides pretty easily and tighten them up. Sound gone.
2 - need more info, where does the sound seem to come from? It could be anything from a loose heat shield to a driveshaft u-joint.
Old Jul 10, 2019 | 05:11 PM
Cjlr3's Avatar
Thanks, Dakota. I tightened some bolts after reading your reply but no luck yet, will take a closer look at it.
For second issue, it’s really hard to tell but the sound seems to be coming from below vehicle or lower engine and on both sides.
Goose2549
Dec 24, 2019 05:51 AM
zegil77
LR4
Dec 17, 2017 01:20 PM
me 2
Jul 12, 2013 11:47 AM
shj3c905
Oct 23, 2011 10:30 AM
cottonpatchweims
Nov 16, 2005 04:52 AM
