EPB and Brake Pad Sensor Light
Old Feb 10, 2022 | 03:43 PM
Oceanguy33's Avatar
Default EPB and Brake Pad Sensor Light
Just a quick question. The EPB needs attention on my LR3 - usual issues. Does this issue usually throw up a check brake pad warning?
I replaced the front sensor as it had broken loose. That seemed to settle the light. Thinking the issues were concurrent but separate.
However, have started it up after a couple of days and it's intermittently binging to check the pads again.
Goes away when the EPB is solved?
Old Feb 10, 2022 | 03:52 PM
DakotaTravler's Avatar
Yes. This is because if the EPB blows its main fuse there must be a fall-back warning - cause brakes are critical. This is actually common in some other cars too, a backup warning of sorts - such as if the parking brake lamp burns out even. But I will say that if you have a hard EPB fault that lights should say one, not be intermittent. So did you check the rear sensor too?
Old Feb 10, 2022 | 03:55 PM
Oceanguy33's Avatar
On my way to double check that actually....
It does flicker on and off and is not a steady light.
lukas
Dec 17, 2019 12:15 AM
lornecci
Oct 14, 2019 04:38 PM
Giusepd
Dec 6, 2015 01:12 PM
Titus
Oct 19, 2015 11:40 AM
tims911
Feb 25, 2014 07:28 PM
