Ford Part Compatible w LR3?!?! NEED ASAP
Old Apr 3, 2017 | 07:32 AM
Harleigh's Avatar
Arrow Ford Part Compatible w LR3?!?! NEED ASAP
I bought a new thermostat for my 05 LR3 4.4 and when it was in it popped out and broke one of the brackets off the housing. Can anyone please tell me if there's a Ford compatible part number for it and, if so, the link for it because I want to get a few other parts as well - especially a new catalytic converter
Thank you all for being so helpful - I'm a girl who knows nothing about parts/issues and when I go to a mechanic or parts store they seem to always want to sell me ten more things I don't need 😤 Everyone keeps telling me tinsel it but no way I LOVE this vehicle.
P.S. I have a genuine Bull Bar w lights (need new bulbs/lenses) - there are no scratches or rust on it at all. It's in great shape - I just want to sell it so I can replace it with a chrome grille - trying to make it a little less masculine 😁 If anyone would be interested please let me know. I'm located in Southeast Missouri.
Old Apr 3, 2017 | 08:41 AM
abran's Avatar
what bracket? Post a pic, I might have a used one.
Old Apr 3, 2017 | 08:58 AM
Harleigh's Avatar
Here's the pic. The clip/bracket on the left is the one broken off.
I appreciate u possibly having one but I need to get it today - are u close to me?
Old Apr 3, 2017 | 09:07 AM
abran's Avatar
No I am not. As far as I know you cannot buy that part seperatly, the entire thermostat housing with thermostat and sensor is sold as a unit.
If you do replace just that piece, I would consider that a band aid and you should be changing the whole assembly. The plastic gets brittle after time and creates cracks/leaks in the assembly.
Good luck
Old Apr 3, 2017 | 09:29 AM
Harleigh's Avatar
Thank you for the info. I'll replace the entire housing but can u tell me where I can find a replacement part from Ford? Our local Ford dealership is not very smart at all ��
Old Apr 3, 2017 | 09:42 AM
abran's Avatar
No idea. The V8 is a jaguar motor and the V6 a ford.
Just because Ford owned them doesn't mean that thermostat housing went on any Ford vehicles.
Eurospare makes one and you might find a Napa or Autozone that can order it for you.
Old Apr 3, 2017 | 10:24 AM
DavC's Avatar
FYI agree with Abran. You do NOT have a Ford motor. the AJV8 4.4L is a Jaguar motor. While Ford did own LR from 2004-2012, parts compatibility is hit and miss. The only component I ever found to be a ford part was the ignition coils.
I would go to your LR dealer or online and order the entire thermostat housing. If you aren't familiar with bleeding coolant loops, this is not DIY. Do it wrong and cook your motor.
Old Apr 3, 2017 | 02:22 PM
Alphamale's Avatar
While the parts for the thermostat housing are available separately this one, New Coolant Thermostat Housing for Land Rover LR3 Range Rover Sport LR005631 | eBay would seem to make it a better buy to get the whole thing. Or you could always try Thermostat And Housing Assembly - Range Rover Sport, LR3 And LR4, but that's a little dear.
Old Apr 4, 2017 | 02:18 PM
LR Techniker's Avatar
I keep genuine Land Rover Coolant Crossovers (aka Thermostat Housings) in stock because when a thermostat goes bad, we replace the whole unit. The crossover itself will eventually start to leak from one of the four gaskets or we see them split where they bolt to the heads. Its a little bit of a pain because the throttle has to be removed to access the lower portion where it bolts to the block, but the part itself isn't very much and is piece of mind.
Old Apr 6, 2017 | 05:59 PM
edhammond's Avatar
You wouldn't happen to have that Ford part number for the coils, would you?
racehorse70
Oct 8, 2012 11:59 AM
Disco2Fever
May 19, 2010 12:46 AM
roveribis
May 8, 2009 09:19 PM
BigMike
Mar 20, 2005 10:51 PM
