Front end dropping!
Old Nov 30, 2020 | 01:47 PM
scoutrover13's Avatar
Right, Well i have no codes as of last weekend. I did have it hooked up to a trailer this past weekend and had a suspension fault several times but no drop outside of the normal front dropping over night stuff. When I say the front end is dropping over night i mean it can sit for 30 mins and it has already noticeably dropped. and more on the driver side.
Like i said i have already tried the rebuild and replacing the valve block unless its a bad block and i did botch the rebuild. which again is just as unlikely both happening as both bags going out at the same time i guess.
What codes do valve block usually show? Let me go pull them real fast see if anything pops up
Old Nov 30, 2020 | 02:02 PM
Ok so maybe these will tell yall something more than they are telling me!Suspension
  • C1A30-64 (6C) Both switches pressed at the same time - Algorithm based failure - signal plausibility failure
    ( on 27-11-2020 09:59:06 at 158170 mi )
  • C1130-66 (28) Air spring air supply - Algorithm based failure - signal has too many transitions/events
    ( on 27-11-2020 18:10:04 at 158207 mi )
Vehicle Dynamic
  • U0132-87 (08) Lost communication with ride level control module - Bus signal/message failure - missing a message
    ( on 27-11-2020 11:58:32 at 158182 mi )
There were others but not pertaining to the suspension that im aware of.
Old Nov 30, 2020 | 03:36 PM
DakotaTravler's Avatar
C1A30-64 - Probably a phantom error, one of those that comes up for no logical reason and usually does not throw a code. If it does throw a fault, then its a bad switch.
U0132-87- Same as above, pretty common background fault.
C1130-66 - Inferred fault that means one thing, leaking bag. Its basically saying that a spring is requesting air too often, the truck has to keep adjusting more often than it should have to.
Old Dec 14, 2020 | 02:23 PM
Update:
So i got the front struts on yesterday. Got them on and man that rear nut on top is a pain!! Anways it seems to be holding but im going to measure for a few days. I can say the ride is much better and way less body roll now. Did not realize how bad and now i wish i went ahead and did rear too. THANKS TO ALL FOR THE HELP. NOW ON TO THE NEXT...
mirepoixmatt
Dec 19, 2017 05:01 PM
packkratt
Dec 10, 2016 11:14 AM
workinghard1713
Nov 18, 2012 05:34 PM
rphotographer
Dec 22, 2010 10:01 AM
tuwrx
Dec 15, 2007 12:16 AM
