front hub noise
Another thing to add is when checking these, you need to get both front wheels off the ground so you can spin the tires by hand. I had a howl noise I swore was in the rear, but after checking the rear and then the front for good measure, it ended up being the passenger front wheel hub assembly. Barely, if any play, but could definitely tell the bearings were noisy when I was able to spin the tire.
Was pass front hub, was obvious once rotor was off, I could move bearing
Super easy, no more noise, no more pull to right so guess alignments ok
Also found outer pad metal shim between the rotor and dust shield all tore up no idea how that happened
Additional found coolant low and oil, pulled skid plates to find oil filter leaking, changed oil topped coolant for now
So was great day in nice weather, heck even washed her
LR Techniker (03-26-2017)
