HDC Switch (Yellow) Replacement ?
Old Jul 21, 2013 | 09:34 AM
yeager6's Avatar
Default HDC Switch (Yellow) Replacement ?
Thank you in advance for your suggestions, what a great forum.
My yellow HDC switch is stuck in the down position (ON ). It does not seem to be the result of an outside influence ( ie Children or Wife ). Ironically, I used another post to fix a problem with my brake switch (thanks again) and everything worked perfectly for 1 day. I then decided to test the HDC, the button depressed but would not return. HDC green stayed on until I shut down, now HDC failure system not available shows in message screen. Battery is 6 mo old and fully charged.
I really think this button is stuck on and malfunctioning b/c it seems dead with no action.
So I removed the floor console upper panel with assistance of another LR post (thank you), and attempted to access the switch.
Question is, can I purchase a HDC yellow switch without buying a whole new console upper panel. Does anyone have a schematic of the floor console upper panel?
I am trying to unseat the white casing below the switch but I am not having much luck.
Any suggestions? I plan to go to the dealer tomorrow and have them look up the parts.
Thanks
Old Jul 21, 2013 | 09:38 AM
You may download the entire shop manual set for the LR3 at link below. Free. Here is a sample section attached.
File Type: pdf
File Type: pdf
Old Jul 21, 2013 | 10:53 AM
unseenone's Avatar
So your suggestion is to download the manual?
Here is the switch at RL parts..
LR3 Down Hill Assistance
2005 LAND ROVER LR3 Parts - Land Rover Parts Center - Call (800) 574-9217 for Genuine Land Rover Parts and Accessories
Old Jul 21, 2013 | 12:25 PM
yeager6's Avatar
Default Thanks
Thank you very much for the fast responses.
unseenone - I appreciate the link. I searched Atlantic British and google but could not come up with the part. Thank you.
I will report back with results of the swap!
Old Jul 21, 2013 | 05:50 PM
My goal was to get the owner all the info so he could make the choice on DIY.
He asked about a schematic, and about taking things apart. Figured the manual was a good place to start. I really don't care where he buys the part.
caseymackenzie
Aug 23, 2006 12:08 AM
demotorcars
Aug 18, 2006 08:09 PM
brianaintright
Jul 19, 2006 06:32 PM
rdunn
Mar 7, 2006 09:30 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
