Headlamp Switch
Old May 21, 2009 | 08:48 PM
amkullar's Avatar
Default Headlamp Switch
I want to get Xenon headlights on my 06 Lr3 se v6. The dealer says that i will need a convertion kit. I asked around and people told me that it might Void the warranty. Is there aany way to get xenon headlights without getting a converting kit. One guy told me about some bulbs silver and blue bulbs. Can anyone hep thansk alot.
Old May 21, 2009 | 11:10 PM
carlitonsky's Avatar
put some hid on ur car... i dont know if it would avoid warranty, but trust me u wont regret it... i think it uses H7, or D2S bulb...
Old May 26, 2009 | 11:21 PM
trynian's Avatar
You can install factory non-adative xenon lights. You have to replace the entire fixture. They are full enclosed units. A bit expensive from the dealer but you can find them from time to time on ebay for a decent price. If patient you can find some for less then $500
I found a set and they work fine.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
There is also an after market kit but I don't think they are quite as nice as the factory.
http://www.landroverworld.org/forums...ad.php?t=13826
Old Jun 2, 2009 | 04:06 AM
trust me , dont give to much mind, if they are aftermarket or not!! put on some 4300k or 6000k hid bulbs, and theyll look the same as OEM.. you can find them like for 200 dollares or less.
Old Jul 10, 2009 | 10:10 PM
snowplower's Avatar
Default headlamp switch
i also wanted to switch the headlights from HALOGEN to HID and i was told that the wiring from the LR3 on the models that use the Xenon is not the same as the models that use the halogen therefore we have no choice but to install a conversion kit or redo all the wiring which tends to be very $$$$$!
Old Jul 11, 2009 | 03:51 PM
trynian's Avatar
Not true. I installed the factory xenons on my se it was straight plug and play. Only the adaptive bi-xenon would require wiring changes.
glovings
Dec 13, 2011 06:55 PM
MarvelVT
Jan 31, 2011 01:06 PM
Darksidetone
Feb 9, 2007 09:15 PM
Snafu621
Appearance & Camping Set Ups
Feb 23, 2006 10:01 PM
englishboyonice
Aug 5, 2005 03:34 AM
