Sponsored by: CARiD
headlamp switch replacement
Old Jan 20, 2010 | 07:14 PM
glovings's Avatar
Default headlamp switch replacement
1998 discovery I 124000 miles
I have been having trouble with my headlamp switch. I put it on bright and it got stuck in between bright and dim and it wont come on. I located another for $150. What would be the best way to take out old switch and install the new one?
Old Jan 29, 2010 | 12:55 AM
sarienbarry's Avatar
4th Gear
If your low beams won't activate, or your lights just won't come on at all, it's likely time to replace your car headlight switch. This is a common problem on cars of all makes and models, and the repair can be done in your garage rather than handing over the money to a mechanic
  1. Disconnect the negative cable from your battery and wait 5 to 10 minutes to allow the capacitors for the airbags to discharge.
  2. Step 2
    Remove any screws around the switch, or pry the retaining ring that holds the switch in place away from the dash.
  3. Step 3
    Slide the switch out of the dash carefully, and remove the wire plugs. Attach a spring clamp onto the plugs to keep them from falling into the dash where they are difficult to fish back out.
  4. Step 4
    Pull the light switch into the on position, press the headlight case button and remove the switch. Using a screwdriver helps if your case has more than one release button. You may have to remove a nut at the bottom of the switch shaft to remove the decorative bezel.
  5. Step 5
    Insert the new car headlight switch into the housing and replace the bezel and shaft nut if necessary.
  6. Step 6
    Attach the wire plugs, taking care not to bend any contacts. Slide the housing and switch back into the dash without binding the connecting wires.
  7. Step 7
    Put back any trim and mounting screws before reconnecting the negative battery wire. Test the switch and the low and high beams.
Old Feb 2, 2010 | 08:45 PM
greg409's Avatar
if you've got the free rave cd, it's simple to remove switch, disassemble, fix (usually dirty) & re-install.
This is assuming you're reasonably mechanical & pay attention during disassembly
Took me less than an hour - works great.
luck,greg
Old Dec 13, 2011 | 06:13 PM
olywa's Avatar
do you have to remove the steering column to replace switch?
Old Dec 13, 2011 | 06:36 PM
No. Steering column is not removed.
Old Dec 13, 2011 | 06:55 PM
olywa's Avatar
the bottom 2 screws are stripped out and i cant get it, i wonder how much the bottom scrhod would cost?
sjfarbs
Jan 2, 2014 08:57 AM
obdoc
LR4
Jan 24, 2013 11:56 AM
MarvelVT
Jan 31, 2011 01:06 PM
amkullar
Jul 11, 2009 03:51 PM
Darksidetone
Feb 9, 2007 09:15 PM
