Headlights keep going out??
Old Mar 19, 2010 | 09:32 AM
bribake's Avatar
Default Headlights keep going out??
I'm on my 3rd set of headlights within the past 9 months..has anyone had any issues with their headlights going out? I've never had any problems up until now. I've been using Sylvania Silverstar Ultra's...
Old Mar 19, 2010 | 04:58 PM
drzjoint's Avatar
are you toughing them with your hands? you cannot touch halogen bulbs with your skin.
Old Mar 20, 2010 | 12:01 PM
Rovin4life's Avatar
there is your problem. You are using crap bulbs. Use OEM bulbs and stop with the crap.
Old Mar 22, 2010 | 01:21 AM
bribake's Avatar
wore a glove, didn't touch the bulb. also, have used the brand in other rover's in the past and they have lasted for more than a year..so I wouldn't say it's because it isn't OEM..thanks for the advice anyhow.
Old Apr 21, 2010 | 03:40 PM
safarisam's Avatar
same problem, and no do not touch the bulbs, went through 3 sets in 2 months. still on the third. to the point where i carry an extra set in the car because i was pulled over. OEM part doesn't mean anything in this case because the first two sets were OEM. Running the sylvania silverstar whatever whatever right now. Im not sure but it seems like everytime i take a dive in a puddle on a weekend adventure, not long after pop goes the headlights. I have just concluded that the headlight assembly is prone to moisture. checked voltage to the light out of curiousity, nothing abnormal
Old Oct 19, 2011 | 10:04 AM
ddpphx's Avatar
Default Headlights Out
Hi bribake and safarisam,
Did you ever find out what was causing your headlights to go out repeatedly?
Thanks,
Danny
Old Oct 19, 2011 | 10:38 AM
May help to use bulb grease on the base contacts. Also might want to check ground wire near lights (if loose) and alternator output volts (if high - wifey's Kia eats those things and has 14.6 volts.... hmmm)
Old Oct 20, 2011 | 12:11 AM
bribake's Avatar
Default Headlights going out
Thanks,
Danny
No, never found the cause. I ended up buying cheaper bulbs just to see if they would last longer and so far they have both been working for the past 10 months or so. I had both OEM and the Sylvania Ultras burn out over and over again..
I feel like it started happening once I moved to the PacNW..more moisture? who knows..
Old Oct 23, 2011 | 05:41 PM
DPM LR3's Avatar
4th Gear
I had the same problem. I ended up using the standard bulbs. I was told the the higher end bulbs burn hotter and are more fragile. It took me about 3 pairs in about 6 months before I learned the cause. I've had the standard bulbs in for almost 2 years.
Old Oct 23, 2011 | 06:05 PM
This is true, thats how they get the brighter light, buy running hotter (more watts), the Silverstars actually melted the wire harness on my Montero.
