Heater Core Replacement
Old Dec 23, 2016 | 03:15 PM
  #21
cybercop's Avatar
Trying to check my air blender on the Drivers side, can anyone give me guidance on how to remove the black plastic panel just under the steering wheel?
Old Nov 15, 2017 | 09:42 AM
  #22
D Brent Barcus's Avatar
hey guys...i'm new and not handy just a fan of owning a RR Sport!! i've noticed a lack of heat on the driver side of my 2006....blowing great and its the same at all vents on the driver side...wanting to exhaust all possibilities before replacing heater core....power flush? how to check the blend doors? motors? any thoughts or ideas?
Thank you!
BB
Old Nov 15, 2017 | 10:41 AM
  #23
abran's Avatar
Check for HVAC system codes.
Old Nov 15, 2017 | 11:05 AM
  #24
delormea397's Avatar
Thank you!
BB
There are a few threads out there where bbyer details a method to check for HVAC fault codes. It involves pressing and holding some buttons and letting the system run a few tests. Button lights flash if there are faults found in operation of the blend door motors.
I removed a couple panels until I could put my hand on the blend door motors and felt them whirring. It's a poor diagnoatic test but... I did it. I also fed a camera down the vents to visualize the blend doors moving.
When I flushed my heater core it flushed just fine. The flush pushes past the blockage that has settled (apparently) to one bottom corner of the heat exchanger. I didn't cut my old heat exchanger open to do a failure analysis but it seems reasonable. Either way, the flush appeared normal, but no change was detected in heat. Replacement of the heat exchanger resulted in an immediate fix
Best,
muddybuddy
Feb 19, 2017 07:06 PM
tnhotrod
Oct 10, 2010 02:48 AM
rrbc
Nov 14, 2009 10:15 PM
kevinfunston
Nov 17, 2007 12:41 PM
97DISCOIDAHO
Sep 6, 2006 04:34 PM
