Help - 2005 LR3 - Warning Lights, HDC, Stuck In Low...and more
Old Feb 16, 2018 | 05:10 PM
abran's Avatar
Originally Posted by houm_wa
Hi Abran, not to jack the thread but what's the shop time for replacing the negative cable?
Book time is .4 hours
Old Feb 16, 2018 | 05:20 PM
Bhalbach's Avatar
will TCCM affect the park brake not disengaging with accelerator? I have to manually disengage it.
There is a connection at the transfer case on transmission correct? Possibly bad connection here?
Old Feb 16, 2018 | 05:32 PM
Bhalbach's Avatar
Another thing I notice is I am not restricted with speed even though it is stuck in low.
I want to check everything possible before getting a new TCCM.
Old Feb 16, 2018 | 06:28 PM
abran's Avatar
don't know.
Old Feb 18, 2018 | 03:03 AM
houm_wa's Avatar
Thanks!
Old Feb 18, 2018 | 01:19 PM
Bhalbach's Avatar
Default Electrical Library for 2005 LR3
Thanks!
Does anyone have the electrical library for the 2005 lr3?
i have found 1 wire on passenger side that I do not know what it hooks to.
Old Feb 18, 2018 | 01:41 PM
Bhalbach's Avatar
Broken wire passenger side “A” post. Appears that this light brown wire goes towards the driver side in the wire bundle above
Based on length, looks like the wire hooks up to this connection.
Old Feb 18, 2018 | 01:51 PM
Bhalbach's Avatar
I am thinking these 2 codes are causing my issue. Any suggestions where/what to look for or test?
Old Feb 19, 2018 | 04:41 PM
Bhalbach's Avatar
Default Hoping I found the issue...TCCM looks to have shorted
Change out TCCM
Abran
I appreciate your input.
i should have opened the TCCM when I saw corrosion on pins...looks to have shorted out.
All my trouble shooting is not wasted...at least all connections are cleaned with electrical contact cleaner and I used dielectric grease on all connections.
From what I have read a new TCCM needs to be programmed correct?
Old Feb 19, 2018 | 07:24 PM
I got lucky and cleaning mine solved the issues I was having. Glad you found the culprit though.
