Help! Front end grinding with hard turns
My truck was acting up a couple of months ago when driving moderately on up and down, twisty secondary roads. Found out shortly there after that my suspension bushings were shot causing a lot of play and probably was what caused the trucks sensors to overreact to the condition and apply the abs and to cut power.
Haven't had a chance to drive the same road since I got the suspension straightened out but I'm almost positive that was my reason.
Try checking your rear suspension bushing for play... you'll need to get it on a hoist and use a long prybar to induce the movement but you will easily see the control arm moving laterally. There should be none but a few millimeters paly would be normal.... mine was over half an inch play.
