How to fix parking sensor sounder with an $18 Ford part
Old Aug 1, 2021 | 04:12 PM
Alex J's Avatar
Default How to fix parking sensor sounder with an $18 Ford part
I've seen it pop up on here and other Rover forums where the parking sensor sounder speaker fails then causes faults for the parking sensor system and then makes the parking sensor light flash in the button on the dash. That last part was super annoying for me having that light flash every time I started the truck. So in my search for a new sounder speaker somehow a Ford part popped up in the images that looked almost identical to the Rover one. I put that part number into Amazon and for only $18 it looks like I can get my parking sensor system working again as the only fault that was in there was for the sounder(speaker). Here are pictures and the part number, hopefully when it cools off later (currently 100+ outside) I'll put this in and make sure it works.
Old Aug 1, 2021 | 10:36 PM
Alex J's Avatar
**Evening Update**
The Ford part works perfectly, electrical connector snaps in place just fine and the screw holes line up as well and it beeps when close to stuff when backing up.
Old Jul 30, 2024 | 09:48 AM
Tstewart1's Avatar
My speaker is extremely quiet. Is there a way to turn up the volume or is that a sign that it needs to be replaced?
Old Jul 30, 2024 | 06:54 PM
Alex J's Avatar
I'm not sure if there is a way to change how loud it is. Mine was just not working at all and this fixed it. It was a bit of work to get at the sounder but for what the Ford part cost it was worth it to not have a rover shop do it or charge me for a genuine part.
Old Jul 30, 2024 | 07:03 PM
loanrangie's Avatar
Out of interest where is this item located in the vehicle ?
Old Jul 30, 2024 | 07:15 PM
Alex J's Avatar
It's behind the trim in the left rear. I have 15 years experience being a tech for a few different brands of vehicles and have a large tool box and it took me about 1-1.5 hours. It's not fun and I cheated and was able to carefully force some trim off without taking some other pieces off that saved some time. By the book taking everything off you are suposed to this is probably at least 2 hours of work with automotive experience.
Old Jul 30, 2024 | 10:56 PM
loanrangie's Avatar
No issue with mine just curious as i thought the buzzer was part of the dash binnacle.
Old Jul 30, 2024 | 11:42 PM
Alex J's Avatar
If you have front and rear sensors there is probably a sounder in the dash area as well but mine only had rear sensors so just a sounder in the back.
journeyman
Nov 20, 2023 04:13 PM
Brandon318
Aug 2, 2021 07:10 AM
Llamasayswhat
Nov 8, 2018 06:29 PM
jeffery212
Sep 3, 2017 04:32 AM
SilverDisco04
Nov 21, 2013 10:28 PM
